Yellow or blue?
Old May 25, 2012 | 09:38 AM
805cut's Avatar
Yellow or blue?
Im not to worried about my car being stolen as I am one of my brothers taking it out for a joy ride. Id like to install a dead switch so the car wont start when its flipped.. Id just hide the keys but the spare set is always around incase of a fire or something of that sort. Screw the important papers and family pictures, just get my car out of there!
Ayways my question to you guys is what freaking wire do i put the toggle switch on?!
the red yellow and black wires run from the top of the coil back into the bottom of the coil, the only wire that trails off into the cab of the car is the blue one, but the yellow wire has something spliced into it which leads me to believe its my hot wire. Which one is it yellow or blue or am i not even in the right spot!?
let me hear it!
Old May 25, 2012 | 09:46 AM
805cut's Avatar
my whole electrical box was ran over by a harley the other day and my wire tester was inside i need to get a new one which would take the guess work out of everything but i figured you guys could help me out
Old May 25, 2012 | 09:51 AM
805cut's Avatar
sorry guys.. the wires thats crimped onto the yellow wire is purple i think i read someplace that this is th ignition wire and the one you use?
Old May 25, 2012 | 01:21 PM
frankr442's Avatar
Most use the purple wire to the solenoid. Just make sure all your connections are as clean as possible, solder and use heat shrink. Breaking into that wire, especially if you're adding a long length of wire, could contribute to a hot start problem as you're adding resistance to an already long circuit.
Old May 25, 2012 | 01:43 PM
Lady72nRob71's Avatar
I agree - put the kill switch inline with the starter solenoid, which is fed by the BIG purple wires at the neutral start switch (base of the steery column).
If you control the ignition only, he may run the starter until the battery is dead...
Wazzou
Dec 28, 2015 04:59 PM
rktolds
Apr 12, 2015 08:35 PM
hinz57
Paint
Apr 14, 2010 06:11 PM
|-K|=K
Sep 29, 2009 09:56 AM
oldtimeclassics
Aug 3, 2006 11:54 AM
