Wiring Harness Vendors: Who's your favorite?
Well, I've finally got everything I need to replace the starter, battery cable etc... but just can't bring myself to reuse the original engine harness.
Which vendor do you all prefer for an original style wiring harness, M&H or American Autowire?
M&H and AAW are only $1 apart on the engine harness for my '71 Cutlass. Rock Auto was $20 cheaper than both, how can they be cheaper than the supplier themselves? It it the same original style harness?
So it's a year later and I'm ready to replace my forward lamp harness, but Rock Auto no longer carries any wiring harness from M&H or American Autowire. Are there any suggestions where I can find this wiring harness at a discount?
I have purchased from both M&H and AAW and had zero issues with either. Both were perfect fit, and quality seems top notch...would recommend either..real purty. I did not have to use cust service so don't know about that. Getting ready to get a dash harness so basically will do a coin toss to decide. Since I work near Yr1 will probably let them handle it...they use M&H I think.
One thing to note is once you start with one manufacturer, you may want to stick with them to keep the same style and shades of wire colors. It's a really minor nit, but one that you might care about.
A little off topic but biggest problem I have is that 67 Olds fuse box not available repo and I have to send in mine as core so car will be down for a while. Just a little pain unless I can find a used one somewhere to send in.
Steven,
Thanks, that was the info I was looking for. Rock Auto used to sell the harnesses cheaper than the manufacturer, and am looking for a similar deal. I'll check out the Parts Place.
Another Vendor to consider
YNZ wiring. They ALSO use the same part numbers and same price. They are in Ca. The wording on their web page is the same as M&H. Sounds like everybody is using the same manufacturer... IDK
Nufo
Nufo
I used Lectric Limited as I think they might actually be the manufacturer for some of the others like AAW.
http://www.lectriclimited.com/
Prices (with multi piece discount) were a bit cheaper than others and when I talked to them it sounded like they were making my harnesses. Harnesses look perfect & the few I've tested so far are 100%...
Xavier777
Feb 24, 2013 08:33 AM
oldsdroptop
Jun 18, 2009 06:17 PM
