wiper problem 1985 custom cruiser
Old Dec 28, 2007 | 08:23 AM
a6m5zerosen's Avatar
1977 Cutlass Supreme
I just picked up an '85 custom cruiser wagon for a hundred dollar bill. It runs great and passed smog but the wipers are completely inoperative. I've checked the fuse-it was good, but I replaced it anyway. I checked the connections at the motor, pump, and under the steering column for the turn signal/cruise/wiper switch and lever; all appear to be clean and hooked up properly. What troubleshooting steps should I take? Thanks!
Old Dec 28, 2007 | 08:33 AM
crazy'boutOlds's Avatar
Check that pesky ground strap. Make sure it's making contact with the motor casing.
Old Dec 28, 2007 | 08:57 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
After your ground has been checked, put a voltmeter on it in all of the various places until you find where the power stops.
Old Dec 28, 2007 | 01:21 PM
kevinkpk's Avatar
I think you will also have to have the key switch on when checking. If you don't have a voltmeter, you can buy an inexspensive test light.
Old Dec 28, 2007 | 11:01 PM
Redog's Avatar
Is the plug in snugly?
Mine was a PIA and kept comming out. Bought a new one at a junkyard for $5
Old Dec 29, 2007 | 04:59 AM
You might want to pick up a factory service manual. Or at least a Chilton's guide. That will have a wiring diagram and will make electrical troubleshooting easier. If you check the ground and so forth just wire 12 V directly to the motor to see if your motor is working. If it works, and you know you have good ground then your power isn't getting to the motor for some reason.
Old Dec 29, 2007 | 09:17 AM
Don't waste your money on a Chiltons/Haynes/et al. Just get a CSM. Be aware that some years used a separate electrical manual. In 1982, for example, the wiring diagrams were a separate volume but in 1986 they are all in the CSM. I unfortunately don't know about 1985.
Also, be aware that GM wiper motors use a weird shunt winding system. The main winding on the motor gives you high speed. A reverse-wound shunt winding is energized in conjunction with the main winding to give you low speed. The shunt winding by itself is used to park the wipers.
Arrowstorm
Mar 24, 2015 03:06 PM
GeraldBelton
May 25, 2012 07:53 AM
a6m5zerosen
Nov 28, 2009 03:58 PM
a6m5zerosen
Jan 3, 2008 05:44 AM
Don Cain
Mar 17, 2007 07:37 AM
