Hi there! Greetings from the Netherlands....
I own and try to repair and improve my precious 1966 Oldsmobile Cutlass Supreme. Many things have been repaired already, but now it needs either a new wiper motor (Delco 4195858) or I have to manage to repair it. So far I can't find anything similar but from Classic Industries A40162 - but then they don't really answer my question if it is similar and or if it has the self-park property.... Otherwise the motors look pretty identical.
I hope to find more information here on how to find parts or repair advise here. Very much appreciated.
The original motor on your car was GM P/N 4915948, which appears to be 1965-66 F85 with round motor. Also used on 1965-66 Chevelle and 1965-66 Chevy full size with two speed motor.
This what is printed on the original part. Question is tho..... Where can I find a replacement part.
I'll add that 4915948 is the part number for the replacement motor without the washer pump (which was available separately). The part number for the motor WITH the washer pump as installed on the assembly line was 5044630. The actual part number for the motor assembly is on a sticker on the round part of the motor. Don't be surprised if that sticker has long since disappeared. This photo is just an example of the sticker location.
