Wiper issue
Old Mar 6, 2024 | 09:03 AM
Jeff Hiles's Avatar
Wiper issue
I have a 64 convertible with 2 speed wipers the only way to shut them off is to unplug the motor even with the switch unplugged
mom
Old Mar 6, 2024 | 09:12 AM
Jeff - Obviously you're getting power to the wiper motor from "some" location other than the switch, right? You most likely already know this. Here's a link to the 1964 wiring schematic. You'll most likely need to find out where you're getting power when you shouldn't be getting power. Most likely a poor connection, it was mis-wired (by someone), or you may have a short? Is it the original wiper motor or an aftermarket? Was it on the car since you bought it? Did you replace the wiper motor?
https://classicoldsmobile.com/forums...arfire-154640/
Old Mar 6, 2024 | 09:15 AM
The easiest method to diagnose this issue is using a Circuit Tester probe to find out which wire(s) should have power & which wire(s) should not have power.
Old Mar 6, 2024 | 02:34 PM
The wiper motor gets power from a wire that is hot at all times. The switch opens and closes the ground side of the circuit. Do you have the round or square two speed motor? The square motor uses a mechanical park switch that holds the circuit closed even with the switch off. A mechanical cam in the motor opens this switch when the motor gets to the park position, turning it off. The round two speed wiper motor uses uses a park relay that serves the same function with a mechanical set of contacts that release the relay. Either these contacts are shorted or the control cam is bad. The wiper circuit and diagnostics are detailed in Volume 4, Chapter 13 of the 1964 Chassis Service Manual, starting on pg. 13-54.
Jeff Hiles
Dec 8, 2023 05:40 PM
DB Cooper
Nov 4, 2023 11:14 AM
rick442
Apr 16, 2018 02:14 PM
64ragcut
Jun 13, 2013 09:47 AM
olds7cutlass7salon
Jan 31, 2009 10:50 PM
