Windshield Washers
Old Oct 29, 2023 | 09:44 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Windshield Washers
I have a new windshield wiper/washer I put on my 75 Hurst about a year ago. I had the car out cleaning it up Friday and when I went to put it back in the garage, the dang windshield washers came on and would not stop. They weren't even turned on and the wipers were not running. I know it is not the switch because I disconnected it and they still run. The only way to stop the washers is to unplug them. This is one of the newer washers and not the old pulse type that came on the car. Has anybody else had this problem and what is the fix? Thanks guys.
Old Oct 29, 2023 | 09:57 AM
You need to see where it is picking up a ground signal to turn on.
Old Oct 29, 2023 | 10:02 AM
redoldsman's Avatar
Thanks Eric. I understand that. I am hoping somebody gives me a logical spot to find that ground before I go taking wiring harnesses apart. That will probably not happen since the washers are rarely used.
Old Oct 29, 2023 | 12:30 PM
Oldsguy's Avatar
Past Administrator
I would suspect the unit itself if there has been no change related to the wipre circuit.
Old Oct 29, 2023 | 03:28 PM
redoldsman's Avatar
Thanks Dan. I don't think it is the washer since it will quit when I unplug it. I am going to get the shop manual out and look at the schematic. The wiper/washer motor is only about a year old. Of course we all know that doesn't mean anything.
Old Oct 29, 2023 | 07:47 PM
Well I don’t follow. Of course it stops when you unplug it. How does that exonerate it from being faulty?
Old Oct 29, 2023 | 07:57 PM
It should be the (I believe) blue wire and it runs directly from the wiper switch. The yellow has 12v at all times when the key is on.
Old Nov 2, 2023 | 05:44 AM
Oldsguy's Avatar
Past Administrator
My thought was that the unit might be providing a ground to activate the motor when it should not be doing that. Might it be possible to un-mount it from chassis ground (firewall) and try to see it it still mis-behaves? Just throwing darts blindly but...
Old Nov 2, 2023 | 06:31 AM
redoldsman's Avatar
Good thought Dan. It has some other goofy electrical gremlins. It has a dome light on each side and neither of them were working. The courtesy lights under the dash work. I played with the right side end could not get it to work. I went out in the garage last night and the dang thing was on (right side only). The doors were closed so I go the headlight switch to see if it is turned all the way to the left. I turn it all the way and the courtesy lights under the dash come on and the dome light goes off. Turn it back to the right slightly and the courtesy lights go off and the done light comes back on. So I took the bulb out so it isn't a drain on the battery. Will get the shop manual out and look at the schematic.
Olds64
Feb 15, 2024 04:59 AM
denf221
May 1, 2018 01:04 PM
young olds
Feb 24, 2014 08:10 PM
Dan Wirth
Aug 22, 2009 11:13 PM
Oldskeeper
Sep 15, 2008 06:59 PM
