What kind of ballast resistor?
Newbie. I viewed some posts about coils and ballast resistors but can’t seem to find out what type of resistor to use for my ‘73 455. It’s a bone stock engine that I’m putting in a rat rod so I’m kind of putting it together from scratch. I’ve seen a lot of resistors that all look the same but apparently drop the voltage in different ways. (???) I don’t want to burn up the coil by putting the wrong resistor in.
You want something that drops 12v down to about 7 volts.
EZ way if you have enough clearance at the back of the engine is to pull the points distributor and install an Olds HEI distributor, which runs on full 12 volts. HEI was optional in 1973.
It depends on the resistance measurement of the coil. You want to measure the coil resistance and the ballast resistor difference should equal 3 ohms. So if your coil resistance is 1.5 ohms then your ballast resistor needs to equal 1.5 ohms. 1.5 + 1.5 = 3
My ‘66’s were born with points & there are lots of good arguments in favor of them. Having said that, I’ve really enjoyed the improved performance from HEI distributors which need only switched 12v to the distributor, eliminating the worry about ballast resistors & burning points.
On the plus side my figuring is that GM got better performance and longevity from HEI vs. points or they wouldn’t have switched in ‘75. Of course the emissions landscape was changing, so they needed to evolve to get the engines cleaner. HEI is a slightly cleaner install too, everything sits on the distributor and you can eliminate one of the starter motor wires.
On the downside, these days the HEI distributors have to much vacuum advance designed in and it’s a good idea to carry a spare module since they die without warning. Also, if the great nuke EMP pulse ever happens, points will work and HEI will not.
Good arguments on both sides, suit yourself & be happy.
Cheers
cf
Cheers
cf
Oldcutlass Thank you! This is the exact info I need as I am not very good with electrical!
So.....in the '72 model I would think they ran a points style ignition, thus there should be either a resistor or resistance wiring in place........does that make sense? How would you check that? Measure the voltage on the positive wire at the coil?
Olds used a resistance wire built into the harness from the firewall connector to the coil. That wire is typically pink and black.
Thanks Joe. I'll check that later today. The engine swap is generating many questions for me........the 403 had an HEI and the 455 is setup up with a points style.......and of course the car's wiring is a mess. I'll probably become a pain in the *** for you before it's over.........LOL.
Thanks Joe, I'll check the voltage on that rogue black/solder/red wire (which I am certain was hooked up to the hot side of the HEI. I'll expect to see 12V, and if so I'll install the ballast resistor. Should I expect to then see around 6V coming our of the resistor, or do they come in various levels of voltage reduction? I'll go after voltage because it's just me working.......
