1970 cutlass instructions for column to floor wiring connectionss
Old Apr 8, 2022 | 10:17 AM
ALT's Avatar
ALT
Has anyone transferred from a column shift to a floor shift? and if so what is the procedure for the wiring?
Old Apr 8, 2022 | 12:20 PM
None of the wiring in the column changes. If you are really asking about the neutral safety switch, it depends on whether or not you plan to retain the backdrive linkage on the trans. If you do, that doesn't change either.
Old Apr 8, 2022 | 02:02 PM
ALT's Avatar
ALT
Ok, I was under the impression that on a 1970 had to be wired for the back up lights to function. Also when I bought the car it didn't come with a center console floor shifter. I have the harness to wire it up but I am not sure if there is connections under the dash.
Old Apr 8, 2022 | 03:01 PM
cdrod's Avatar
Rodney
Isn't the neutral safety switch mounted to the console shifter in a '70 Cutlass/442?? Or was that switch for the backup lights?
Old Apr 8, 2022 | 03:07 PM
The point is that if the car already has the column-mounted NSS and the backdrive linkage, there's no wiring needed. You don't HAVE to duplicate the 1970 configuration, you can mimic the later cars with less work.
88hurstolds
Jul 13, 2017 05:59 AM
Gary M
Mar 11, 2017 05:57 PM
CheyenneTransAm
May 8, 2015 06:53 PM
joeyg
Mar 3, 2015 05:36 PM
442dale
Feb 7, 2013 07:03 PM
