What do battery group numbers mean?
Old Nov 1, 2019 | 08:06 PM
Oldssupreme's Avatar
Chris
Hi! So I'm looking for a battery for my 1972 stock cutlass supreme that I will drive three seasons here in jersey as to not rust out from road salt. I see there's been a lot of talk about CCA and brand, but whether I go with a NAPA or a auto craft or Walmart battery, how do I know which model to get? Seems like there are so many models that will "fit" but what do the group numbers and letters mean? Thank you!
Chris
Old Nov 1, 2019 | 08:26 PM
Charlie Jones's Avatar
Phantom Phixer
The battery " group " is determined by the physical size ( length , width , height ) of the battery as well as the type and arrangement of the battery terminals .
You should get the proper " group " battery that was recommended by the manufacturer to make sure the battery will fit in the vehicle properly .
CCA is cold cranking amps . And refers to the strength of the battery to crank an engine while cold . Get the highest CCA you can afford to get the best cold weather performance .
Old Nov 1, 2019 | 08:32 PM
Sugar Bear's Avatar
X2 ^^^.
Do a search on BCI Battery Group Size Chart, it provides all of the specs Charlie Jones mentioned for each group size.
Old Nov 2, 2019 | 03:43 AM
72455's Avatar
1972 U code Supreme
'72 Cutlass Supreme takes a 78 group size...and as stated above, the more cold cranking amps, the better. Also, the higher rated batteries come with a better warranty.
Old Nov 2, 2019 | 09:12 AM
I generally agree with this, but he said he won't be driving in the winter. But yeah, going with what the manufacturer recommended is a good idea.
I live in a warm environment and cold cranking is not a thought in my mind. The link below has some good info for those of us who live in warmer areas:
https://www.mechanic.com.au/news/how...ou-really-need
Old Nov 2, 2019 | 09:52 AM
The higher CCA rating usually includes a higher reserve capacity. That’s how long a fully charged battery can support a constant 25 amp load and not drop below 9.6volts (I think). Basically, useful if you run accessories with the engine not running, or how long you can drive with a defective charging system
Old Nov 2, 2019 | 08:08 PM
svnt442's Avatar
Group 78 is the larger side terminal battery. Don't be tempted to use the 75 in it's place because it might save a few bucks. If you plan on running an electrical accessories it might be a good ides to grab a dual terminal 34/78 and connect the accessories to the top post. It makes for a much cleaner install and you won't mess with the main cable connections to the car.
Old Nov 3, 2019 | 03:34 AM
Chris
Thank you all for your replies! Much appreciated!!
Chris
FStanley
Feb 28, 2023 02:48 PM
76olds
Mar 3, 2014 03:31 AM
VikingBlue
Feb 11, 2012 10:24 AM
Kattosha
Nov 21, 2010 03:45 PM
68Tom
Mar 20, 2009 08:50 AM
