Volt meter hookup
Volt meter hookup
Hello,I'm installing a Volt meter in my 71 cutlass S with 350.My question is do I go from Horn relay to gauge and other side of gauge to Battery?.What about the idiot light.Thanks for any help.Tom
The backlighting will need to be spliced into you headlight/gauges circuit so the are only lit when the light are on. Other will chime in on the wire locations.
Adam
^^ Pretty much that's it.
Do you have wiring diagrams for your car? They will help a lot.
I like splicing by cutting the wire entirely. stripping the sheet, then twisting the two wires together ( car's wire and new gauge wire) on one side and just the car wire on the other side of a 22-18 butt conector. Hasn't failed my yet (going on 10 years now)
