Vacuum Advance problem?
Old Nov 2, 2007 | 10:30 PM
Redog's Avatar
OK I've been pulling my hair out about this for a few months now and I'm no closer than I was back then.
I think I narrowed this down to Vacuum Advance on the dis, but I need some calarifaction. I read that if the advacne isn't working right, the RPMs will run a bit high.
Here's the problem:
I switched to HEI from the points on my Delta project. The RPM's were right on the money with the 3.42's in the rear end. (eg 2500 RPM @ 55 MPH and 3000 RPM's @ 70 MPH)
After the HEi was put in, the RPM's are off by about 15 MPH, the car is revving at 3000 RPMs when only going 55, and 3500 RPMs at 70. I think the vacuum advance thingy on the dis is messed up, and I'm thinking of replaceing it. The vacuum advance thing was replaced on the points ign before dropping the motor into the car.
Is this the problem? will this fix the problem I'm having?
Old Nov 3, 2007 | 06:24 AM
You can get an adjustable vacuum advance modulator for your distributor. This would be a good investment for your car. Then you can play with your total vacuum advance. You can also buy different springs for your mechanical advance so it kicks in at different rpms.
I would suggest taking the mechanical advance springs and the vacuum advance module off of your points distributor and putting them on your new distributor. They should fit. Then you would be at a zero point and you can tune from there.
Old Nov 3, 2007 | 08:59 AM
Jerry Weitz's Avatar
Here's the problem:
You can check you timing with and without the vacuum advance for one thing. Also you might use another tach to see if your in car tach is the same. Sounds like you might have a false tachometer reading after switching to HEI
Old Nov 3, 2007 | 11:24 AM
88 coupe's Avatar
Junior Member
........I read that if the advance isn't working right, the RPMs will run a bit high .........
Advance (mechanical or vacuum) has nothing to do with the signal to the tach.
Assuming clean/tight power and ground connections:
The pulses from the points would have been under 12V and from the HEI, over 12V. If that makes a difference in the readings, I would suspect a faulty tach.
Norm
Old Nov 3, 2007 | 01:28 PM
kevinkpk's Avatar
I had to replace my distributor due to the advance worn out, I'd have to reset it after a couple weeks of driving as it would be to far advanced, and hard to start, try this for some good reading..
Vacuum Advance Tech - Setting the Timing Curve and Tuning - High Performance P
Old Nov 3, 2007 | 02:56 PM
Redog's Avatar
I know the tach is good. I can hear the car revving 500 RPM's higher.
At the track the car used to cross the finsih line at 4100 RPM's now it's at 4600
Old Nov 20, 2007 | 03:48 AM
Jim's rare 80's Avatar
Jim's rare 80
Just a thought. Were did you hook your line fron the dist. advance to?
Old Nov 20, 2007 | 06:27 PM
texasred's Avatar
Tom Servo's Stunt Double
"True" RPM (actual engine revolutions per minute) at any given MPH is a function of differential gearing, tire size, traction and transmission slippage (auto or clutch). Don't confuse a measurement of revolutions with actual revolutions.
The signal from the tach, wiring, or tach may be going bad or need to be recal'ed, but you didn't change the "true" RPM with a different distributor.
C.J.
Old Nov 26, 2007 | 05:01 PM
Redog's Avatar
The carb, could this be it?
Old Nov 27, 2007 | 03:46 AM
Jim's rare 80
The vac. line from the dist. should go to a "TVS", thermal vacuum switch, then to ported vacuum on the carb. The tvs just stops vacuum to the dist. when cold. If you are going straight to the carb, then make sure you are plugged into ported vacuum. These are the ones coming out of the bowl area of the carb. The ones coming out of the bottom throttle plate are manifold vacuum. Check to see for sure.
Hope this helps.
Old Nov 27, 2007 | 04:48 PM
Redog's Avatar
^^ OK I think I understand a little bit better now.
I have 2 vacuum ports on the front of the carb. (It's an Edelbrock model number 1806)
(Looking at the carb head on) The port on the left (electric choke plug side) is a "timed Vacuum port" and has 3/16" vacuum off idle, I have the tranny pluged in here, and on the right side I have the vacuum advance pluged in there and it is a "manifold vacuum port" and 3/16" vacuum at idle.
So I guess I just have to switch them, is this right?
Old Nov 27, 2007 | 05:10 PM
67olds's Avatar
vac advance fun
Redog,
Dealing with similar issue now on Chevy small block in 67 cutlass (wish it was an Olds 330). If your timing is already set using manifold vacuum connection, expect your timing to change significantly after switching the vac line to timed port. The (hopefully) 16-18" of idle vacuum present on the manifold port won't be there on the timed port.
Obviously, its no big deal, but expect to re-adjust timing. Going to switch mine this coming weekend. Tranny should be happy on manifold vac port.
Good luck,
jeff
67 cutlass supreme convertible
Old Nov 27, 2007 | 06:14 PM
Redog's Avatar
IDK.
My buddy pulled the advance off at the track and the RPM hit the same exact point.
I'll try it though
Old Nov 28, 2007 | 12:57 AM
Jim's rare 80
Yes. Put the tranny line to manifold port, then before you connect the vac line up, plug it, and set your timing with vac line to the dist. plugged., then re-connect it to the timed side. let us know how it goes.
Old Nov 28, 2007 | 01:27 PM
Redog's Avatar
^^ Will do, but it will still be 2 weeks before I can drive a car again.
Broke my right foot 3 weeks ago today
Old Nov 30, 2007 | 03:05 AM
Jim's rare 80
WHAT??? Tuck your right foot back, and drive with the left. What a new experience that woud be.
Old Nov 30, 2007 | 01:48 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Redog......
I believe Oldsmobile started putting automatic transmissions in their cars for the sole purpose of giving our 1 legged war veterans the joys of driving again
Old Nov 30, 2007 | 04:29 PM
Redog's Avatar
HA HA HA My wife told me to do the same thing.
Could probably do it with the Delta, but no way with the Alero. I can't even get my boot between the brake pedal and the center consol LOL
Old Nov 30, 2007 | 11:50 PM
88 coupe's Avatar
Junior Member
Could be an interesting discussion if one wanted to start a new thread.
Norm
Old Nov 30, 2007 | 11:54 PM
88 coupe's Avatar
Junior Member
........ The tvs just stops vacuum to the dist. when cold ........
Just?
Or, in addition to, the switch to manifold vacuum if/when the engine overheats?
Does it have a second valve I am not aware of?
Norm
Old Dec 6, 2007 | 08:36 PM
Redog's Avatar
I switcthe lines today but didn't drive it too much. I did manage to put the car sideways in my parking lot. It was fun, until it started to get away from me.
Anyway, The idle has dropped from 800 to 600 while stopped in gear and from 900 to 750 while in park. I'm going to bump up the idle a bit over the weekend, but it seems to be running a bit better (except for the bit of a rough idle and being 600 to 550 while stopped)
I still don't have a speedo, but I'm going to try using the wife's GPS and cruise down the road, It reads about 3 MPH too fast, but that's cool.
I did notice my tranny slipped a bit after the switch. It has a pretty bad leak and I put in a pint on fliud today, I'm thinking it was just a bit low (looked low on the stick) Plus is wasn't much above 30* here today. My Alero's tranny slips if the car isn't fully warmed up when it's under 20* The Delta's tranny didn't slip after the car was warmed up and it was spinning the wheels with no problems
Old Dec 6, 2007 | 11:03 PM
88 coupe's Avatar
Junior Member
........ I did notice my tranny ........
I still don't do trannys. http://www.urbandictionary.com/define.php?term=tranny
........ slipped a bit after the switch ........
Following is from post #8.
Originally Posted by texasred
........ RPM ........ at any given miles per hour is a function of differential gearing, tire size, traction and transmission slippage ........
A slipping trans would explain your RPM/speed discrepancy.
Norm
Old Dec 7, 2007 | 01:14 PM
Redog do you have that 200c metric behind your 350? If so, your problem is right there. I thought you put a 400 in though...
Old Dec 7, 2007 | 07:16 PM
88 coupe's Avatar
Junior Member
Although highly unlikely, at your power level, a "ballooned" converter is another possibility.
Norm
Old Jun 21, 2012 | 06:19 AM
bapa1944's Avatar
Drive a 1963 Olds Super 88 Holiday coupe
Hi everyone I just joined and this is my first post.Recently the 394 started to idle rough so I changed the points and rotor when I put the dwell meter on and adjusted the dwell to .30 the meter was jumping all over the place when I reved the engine the meter became constant could this be a dist problem?
Old Jun 21, 2012 | 06:44 AM
Do you think perhaps your dwell switches may be dirty. Is your curb idle set correctly? Did you reset your timing and carb after the dwell change?
Instead of resurrecting an old thread, in the future you ought to start a new one.
Old Jun 21, 2012 | 07:21 AM
bapa1944's Avatar
Sorry, Next time I will start a new thread,still learning my way around.
Old Jun 21, 2012 | 08:05 AM
I understand! So what about my questions?
pcard
Feb 11, 2013 05:09 PM
stlbluesbrother
Oct 7, 2012 07:07 PM
88 coupe
Jul 31, 2008 08:54 AM
88 coupe
Mar 14, 2008 11:16 PM
harleyrules
Nov 16, 2007 05:27 AM
