Turn signal short
Old Jun 30, 2007 | 05:31 PM
72 Supreme's Avatar
Unhappy Turn signal short
My 72 Supreme just started blowing the signal light fuse as soon as the key is turned on also the buzzer keeps sounding when the drivers door is open. The hazard lights still work fine does anyone have any clues what could cause this.
Doug.
Old Jun 30, 2007 | 06:25 PM
ozoneblue's Avatar
Unplug T/S switch harness at column then re check. eliminate the switch first .Has a stereo been recently installed ? Power ACC wire grounded out .
Old Jul 2, 2007 | 11:39 AM
72 Supreme's Avatar
Thumbs up
Thanks Larry,
I'll give that a try as soon as I can get back out to the garage.
Doug.
Old Jul 4, 2007 | 05:24 AM
Jim's rare 80's Avatar
Jim's rare 80
Hi. Sounds like a problem in the steering column. Could be a broken spring shorting things out. Is your turn signal cancel cam working ok? Let us know. Jim.
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
martine
Jan 22, 2009 01:13 PM
allthumbs
Jan 8, 2007 02:24 PM
js_specials
Aug 18, 2006 10:31 AM
