Turn signal problem
Old Mar 24, 2022 | 10:07 AM
WalterD's Avatar
Turn signal problem
I have a 1965 442 have had for a long time … when I start the car up and put turn signal on it does not work and alternator light come on … also when air conditioning is turned on (does not come on) alternator light comes on .. I have checked voltage at battery 14.35 volts with or without turn signal/ air on … brakes work .. car starters up just fine head lights work high / low beam .. any help would be nice
Old Mar 24, 2022 | 10:11 AM
tkcutlass's Avatar
Ground problem perhaps?
Old Mar 24, 2022 | 10:15 AM
^^x2^^
Clean all ground points. Remove the cable(s), clean the end terminals on the cable(s), sand/clean each of the end terminal metal attachment points. Electrons (electricity) flow from GROUND (-) to POSITIVE (+) side of your battery.
EDIT: The most likely suspects are: Battery cable (ground=negative) to engine & battery cable (ground=negative) to chassis/frame. That's the starting point. Continue to locate any additional ground (-) terminal/cable points and clean them as well.
Old Mar 24, 2022 | 10:43 AM
WalterD's Avatar
Thank. Will try cleaning grounds up
70CutlasMM
Aug 13, 2021 03:15 PM
stephenca118
Jun 8, 2017 03:50 PM
gabe442
Jun 9, 2012 10:07 AM
allthumbs
Jan 8, 2007 02:24 PM
js_specials
Aug 18, 2006 10:31 AM
