Turn Signal Flasher - LED Compatible
Hi All,
Im attempting to switch my front turn signals to LED (all my other bulbs/headlights are already LED). With the current stock flashers, the LED’s are not operating correctly and my assumption is that the power draw is less, resulting in the flasher not being compatible. Any suggestions as to what type of flasher I should look for and from where?
LED's will not work with the OEM style flasher. It takes an electronic flasher and they are available on eBay. The reason why the LED's won't work with the OEM type is,the OEM works off current draw and the LED's do not have enough draw to activate the flasher. There are different style electronic flashers but I used a solid state unit in my 66.
Example;
https://www.ebay.com/itm/3Pin-Electr...kAAOSwJnRfUYms
