Turn signal cancelator
Old Jun 10, 2015 | 05:17 PM
Stevec's Avatar
I need to change the turn signal cancelator in my 68 442.
I have the part but this looks like it's going to be a pain in the a$$.
Has anyone done this and if so any tips would be appreciated. Doe anyone know where I can find directions?
Old Jun 10, 2015 | 06:36 PM
Naah. It's not hard.
Tip: It is FAR easier if you use a lock-plate puller ($15-$20 at your local parts store) than if you use two pointy screwdrivers, both hands, and both feet, like I usually do.
In your Chassis Service Manual.
Old Jun 10, 2015 | 07:16 PM
nsnarsk65cutlass's Avatar
68 no lock plate.
Old Jun 11, 2015 | 01:14 PM
Stevec's Avatar
Eric, your only a couple of hours away! Why don't you cruise on down to Ct and hook a Ginny up! Lol
I looked in the chassis manual and didn't find anything but I'll take a second look.
Thanks guys
Old Jun 13, 2015 | 11:02 PM
Ow, you made me remember back in the 80s sitting in the drivers seat, with my feet on the steering column, trying to get that lock plate off. Bad memory - I'm prolly gonna have nightmares for the next week!
Old Jun 14, 2015 | 05:09 AM
Okay, I was wrong.
I just looked through the '68 CSM, and there is no specific information about changing the cancel springs (presumably because GM didn't sell them separately, and expected you to change the entire switch).
Essentially, remove steering wheel, remove anything you see between steering wheel and switch, when you can get the the switch you will see the two springs, remove them and replace, then reassemble.
Sorry I don't have anything more specific.
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
martine
Jan 22, 2009 01:13 PM
allthumbs
Jan 8, 2007 02:24 PM
js_specials
Aug 18, 2006 10:31 AM
