Trouble with the courtesy light fuse
Old March 9th, 2017, 07:16 AM
77ricbaez's Avatar
My brother has an 87 Buick regal with an olds 307 and none of the courtesy lights come on.
The fuse is blown obviously so I replaced it. And I noticed that as soon as I replaced it, the engine compartment light blew then shortly after came the fuse. This light is part of the circuit.
I have an inkling that this is my problem, if I remember when I took my physics class we learned about circuits and I remember learning that if say a light bulb were to short out then the circuit it incomplete.
Do you guys think that the problem is just the bulb, or is it something deeper. I haven't checked the circuit with my multimeter yet, and I plan to do it soon.
77ricbaez is offline
Old March 9th, 2017, 07:26 AM
A light bulb is a controlled short. If you are replacing the fuse with the proper amp rating and it blows, what you probably have is a short in the positive wire some where in the circuit causing the fuse to blow.
oldcutlass is online now
Old March 9th, 2017, 07:32 AM
77ricbaez's Avatar
positive wire as in the power cable?
Old March 9th, 2017, 07:41 AM
77ricbaez's Avatar
Oh OK I see what you're talking about.
Old March 9th, 2017, 08:00 AM
77ricbaez's Avatar
Well by looking at this, theoretically, if the engine bay light blows won't there be excessive power in the circuit therefore overloading the fuse?
Old March 9th, 2017, 08:26 AM
RandyS's Avatar
Lights only draw what they draw. Having less lights active will not blow a fuse. A short to ground will blow a fuse.
RandyS is offline
Old March 9th, 2017, 08:35 AM
77ricbaez's Avatar
Oh Okay that makes sense, that isolates the problem to the courtesy section of the light switch and onwards since the headlights, parking lights, tail lights are functioning properly. I should look at the junction block and check for continuity.
Old March 9th, 2017, 11:22 AM
If you are blowing a 20A fuse, you have a short somewhere in the orange wires to the cig lighter, clock, courtesy lights, engine comp. light, or glove box light. Since the engine comp light lights and goes out with the fuse blowing, I would say your problem is not there. If the courtesy lights briefly light also until the fuse blows, I might rule them out also. Chances are the short is in the cig lighter, remove the heavy wire at the back of the socket (it should just pull off) and replace the fuse, if it blows the issue is somewhere else.
Old March 9th, 2017, 03:16 PM
77ricbaez's Avatar
Yeah that's what I was thinking, I read that the g bodies have weird wiring and that the cig lighter is a culprit. I noticed that this one is a new one when I took the center console apart. It wasn't the original part which gives me the suspicion that the previous owners had this problem. I might just end up removing it and taping off the connection with electrical tape. My brother's not a smoker.
Old March 14th, 2017, 12:44 PM
77ricbaez's Avatar
Bump!
Any particular way to remove the cigarette lighter? Pulling out the AC controls gives me access to the back of it. How does the thing go out?
​​​​threaded?
Old March 14th, 2017, 01:44 PM
The lighter itself or the socket? Can you just reach the wire thats plugged on the back and disconnect it for your testing instead of removing the whole unit.
Old March 14th, 2017, 08:03 PM
77ricbaez's Avatar
Yes, I found that to be the problem. I am talking about the lighter itself.
Old March 15th, 2017, 06:48 AM
It just pulls out.
Old March 15th, 2017, 03:38 PM
77ricbaez's Avatar
Thank you very much!
Oldscutty72
December 28th, 2015 01:56 PM
NINETY_EIGHT_REGENCY
May 18th, 2014 07:12 PM
1BOSS83
November 11th, 2013 11:28 AM
86Regency
February 23rd, 2011 05:58 PM
Denm33
May 28th, 2008 07:35 PM
Quick Reply: Trouble with the courtesy light fuse
