Top post battery cable ends
Old Nov 7, 2014 | 07:54 AM
rktolds's Avatar
What is everyone running for battery cable ends? I have a set that you find in the parts stores. The neg cable is loose because the connector is wider at the bottom that at the top of the terminal. So I want something that is snug all the time. Any help appreciated.
Matt
Old Nov 7, 2014 | 08:15 AM
RandyS's Avatar
Matt
I think most of us use the terminals with the bolt at the end. The cable terminals are tapered to fit on the battery terminal which is also tapered. There are 2 different sizes of cable terminals based on whether it is for Pos or Neg, with the Pos being the larger of the two. You might check to see if your neg cable has the larger hole, like the pos one.
Old Nov 7, 2014 | 08:27 AM
rktolds's Avatar
Thanks. That may be the problem.
Old Nov 7, 2014 | 09:09 AM
RetroRanger's Avatar
72 Olds CS
This came up before and someone mentioned battery post shims, they should be availible at most auto parts stores or here
http://www.amazon.com/s/ref=nb_sb_no...ery+post+shims
Old Nov 7, 2014 | 11:09 AM
rktolds's Avatar
Thanks. That should work.
Old Nov 7, 2014 | 12:12 PM
RandyS's Avatar
Those will work, but you want to make sure that you get the battery terminals and the cable end terminal shiny clean before putting it all back together. Lead is not a great conductor and you want to be able to pass all the juice you can.
Old Nov 7, 2014 | 01:28 PM
brown7373's Avatar
Be careful with replacement ends. They are many times the place corrosion sets in and increases resistance and decreases starting power. Replacing the whole cable is also an alternative to consider.
Old Nov 8, 2014 | 06:53 AM
You can remove the bolt and grind some of the metal out of the gap. That will allow it to clamp tighter until you find a replacement.
Texas442
Mar 28, 2013 07:13 PM
Jamesbo
Jan 21, 2010 05:23 AM
w-30dreamin
Jan 9, 2010 03:19 PM
1968 42
Apr 13, 2008 12:19 PM
