Timing HEI dstributer
Old Sep 4, 2017 | 07:29 PM
kc1971's Avatar
Originally Posted by B Mill
Wondering if there are any fitment issues with HEI Distributors in 69 Cutlass. I'm sure this has been asked and answered. Also which ones have given the best results. Not going to the strip just want reliability.
I have an issue I have a big block 455 motor with an HEI dstributer in it my uncle put in a mister gasket Waite and spring kit but he put in the wrong springs and my car is still desiling when I shut it off please help frustrated
Old Sep 5, 2017 | 07:47 AM
Dieseling has nothing to do with the WEIGHT and spring kit. You need to double check initial timing, idle speed, carb settings, etc. Hard to provide useful info without knowing more details about your car.
Old Sep 5, 2017 | 07:58 AM
Dieseling is usually caused by a hot spot that ignites fuel to allow the engine to run on after the spark is turned off, hence the name. As Joe stated above you need to see what is causing this and it could also be as simple as excess carbon build up inside the combustion area.
Old Sep 5, 2017 | 09:01 AM
TripDeuces's Avatar
You're probably talking about run on which might be too high an idle speed. If you advanced the timing at all the idle speed would have increased.
djchunter
Mar 17, 2016 03:57 PM
joepenoso
Jun 4, 2014 01:56 PM
oldscruiser
Feb 15, 2011 12:44 AM
442scotty
May 13, 2009 05:42 PM
Redog
Sep 13, 2007 08:43 AM
