Tic-toc-tach adjustment
Old Jun 19, 2010 | 06:08 AM
mmurphy77's Avatar
My '71 factory tach reads high (I have 4.56 gears using the gearing calculators!). I've read here there is an adjusting screw on the back of the tach. Can I adjust this with the car running and comparing it to a Fluke meter readout or is it for a 'bench' calibration only? TIA.
Old Jun 19, 2010 | 08:20 AM
ROCKET VAPOR's Avatar
Lance
Mike, Before I sent my tic-toc-tach to John at Redline Gauge and Clock Repair for a tachometer calibration and clock repair, he made me peal back the foil sticker on the backside of the tach housing and calibrate it to my tach / dwell meter while it was hooked-up in the car.
So....the short answer is yes, you can calibrate your tach in the car.
Old Jun 19, 2010 | 05:11 PM
mmurphy77's Avatar
Thanks Lance, I'll try that!
Old Jun 21, 2010 | 11:55 AM
mmurphy77's Avatar
Well, today I pulled the tach and compared to a digital induction meter and sure enough it was off by about 800 rpms above 2000 rpms. I peeled the foil back and adjusted the phillips screw with it running (BOY is it sensitive!) and it worked perfectly. Thanks for the help again Lance!
Old Jun 21, 2010 | 12:02 PM
Lance
John at Redline Gauge and Clock Repair stated that the deteration of the yellow paint on the needle hand (pointer) will cause the tachometer to loose its calibration. So...the adjustment and the needle are both VERY sensitive.
Old Jun 21, 2010 | 03:06 PM
mmurphy77's Avatar
So just the loss of paint mass from the needle will affect it!? Wow that IS sensitive!
Old Jun 22, 2010 | 05:59 AM
Lance
Yes, John stated that the needle (hand) is very long and "Z" shaped, therefore and loss of weight at the tip will greatly affect its calibration.
70cutlasssupreme
Jan 24, 2022 02:30 PM
gdam
Mar 10, 2008 05:40 PM
TheRuss
May 23, 2007 03:57 PM
