Testing wiper switch and motor
Old Sep 24, 2016 | 08:35 AM
young olds's Avatar
The wipers quit working on my 66 and I'm hoping to test the switch and motor before I start replacing stuff. At first they worked but seemed like every other time I drove it they wouldn't work until they stoped so I got under the dash and pulled the wires off the switch and put them back on and the wipers worked again. Now I'm getting nothing out of the wipers, I'm getting power to the switch and power on the yellow wire at the motor
Old Sep 24, 2016 | 09:48 AM
The wiper switch is supplying a ground to the wiper motor through the light blue wire. The dark blue wire is supplying a ground for the washer pump at the the motor. The yellow wire is unswitched power from the fuse box to the motor.
http://people.ucalgary.ca/~csimpson/...ass_Wiring.gif
Old Sep 24, 2016 | 11:19 AM
m371961's Avatar
The Chassis service manual has good info for this and without it, it can be tricky to understand. (at least it was for me) As said above, the switch controls the ground side of the circuits and the motor is hot full time. I suspect a ground problem at the switch with intermitent operation.
Old Sep 24, 2016 | 11:20 AM
young olds's Avatar
That's good to know, had no idea that's how it worked, thanks
Old Sep 25, 2016 | 09:58 AM
junkman005's Avatar
ok i was reading this i took a test light and it doesnt seem like im getting power on the yellow wire by the wiper motor , i checked both sides of fuse and power on both sides
Old Sep 25, 2016 | 04:22 PM
See if you have voltage at the bulkhead connecter and that its tightly secured.
Old Sep 26, 2016 | 06:43 PM
junkman005's Avatar
OK what and where is the bulkhead connector
Old Sep 26, 2016 | 06:55 PM
Under the master cylinder, where all the wires go to and from the inside of the car.
Old Sep 26, 2016 | 08:46 PM
junkman005's Avatar
OK I see it, looks pretty dirty so I am going to disconnect it and try to clean it up. Thanks for the help there i hope this solves it
Old Oct 2, 2016 | 03:35 PM
young olds's Avatar
finally got a chance to look at my wipers. turns out the motor was getting rusty inside, cleaned it up and its working again. i know it wont last long but atleast i have wipers for now.
Old Oct 2, 2016 | 04:32 PM
You never know, it may out live you. Glad you got it.
Old Oct 2, 2016 | 11:00 PM
young olds's Avatar
That is absolutely true
Old Mar 21, 2020 | 07:16 AM
seanm12's Avatar
gwunta
Jun 22, 2024 08:59 AM
esisson
Jan 1, 2015 02:25 PM
Macadoo
May 19, 2014 01:13 PM
brandon reynolds
Dec 18, 2013 03:05 PM
arodenhiser
Nov 9, 2010 11:53 AM
