Testing oil presssure senders
Old Apr 5, 2018 | 03:51 PM
11971four4two's Avatar
MOTORHEAD
Any bright ideas how best to test these??? All my cars have hard plumbed mechanical gauges now.
brian
Old Apr 5, 2018 | 04:48 PM
RandyS's Avatar
ug
no
toss
em
Old Apr 5, 2018 | 05:14 PM
MOTORHEAD
Originally Posted by RandyS
ug
no
toss
em
Glad we have an expert on the scene
Old Apr 5, 2018 | 06:48 PM
If the wire is still in your car, you can hook them back up and test them. Or possibly with an ohm meter.
Old Apr 5, 2018 | 07:16 PM
MOTORHEAD
and there are none
Old Apr 6, 2018 | 08:12 AM
TripDeuces's Avatar
Make a fixture out of black iron pipe, 1/8 npt bushing on one end and air chuck on other or some such arrangement of your choice. Pressurize it with compressed air. If you want to get fancy you can add a regulator and pressure gauge. Check resistance with an ohm meter.
Old Apr 6, 2018 | 11:04 AM
MOTORHEAD
My compressor clips at 175 psi WAY too much for that
I can check static / not under pressure / with a meter
Thanks 4 your reply TRIP
Old Apr 6, 2018 | 06:19 PM
Funkwagon455's Avatar
At my work, we use dead weight testers to simulate oil/hydraulic pressure on aircraft and helicopters for testing,syncing,calibrating oil/hydraulic pressure gauges and torque gauges that translate pressure.. Of course they are rather simple and archaic in design, but still are expensive and not generally used in automotive applications. As Trip had mentioned, I think I'd hook up an inexpensive air regulator to the sending unit plugged into the car harness with a ground wire attached to the body. Slowly, incrementally increase air pressure 10 psi at a time and observe your in dash instrument. If it is close to mirroring the functional gauge then I'd say you are in business.
Old Apr 7, 2018 | 03:31 AM
Ozzie's Avatar
brian
Light senders or gauge senders?
Old Apr 9, 2018 | 07:57 PM
MOTORHEAD
These are for gauge
Apr 4, 2018 08:05 PM
jensenracing77
Mar 9, 2016 04:37 PM
rr69ho
Dec 4, 2014 05:04 AM
bluecab
May 13, 2014 03:20 AM
roadwarrior
Sep 26, 2013 11:46 AM
