Temp gauge
Old Apr 18, 2013 | 10:28 AM
spate51's Avatar
Temp gauge
Has anyone done a current flow check of a rally pack temp gauge? Seems that no matter how many senders I try, always get a center of scale reading (hot or cold). As the resistance of the sender changes as it gets hot, should cause a current change that causes the needle on the gauge to move. I know the engine temp is good (when hot) (checked with an IR temp scanner) but I am stumped on the gauge.
Any suggestion appreciated. Thanks.
Steve P
El Paso
69 Cutlass S
Old Apr 18, 2013 | 12:18 PM
69'442's Avatar
When you installed the sender did you use any teflon tape or paste. I did and that threw off my gauge reading. I removed it and cleaned it and reinstalled it and it worked fine.
Old Apr 18, 2013 | 12:44 PM
Redog's Avatar
Yeah. Your supposed to use the Teflon, but only so much that the treads actually come thru the tape when installed.
Try without any tape, if it leaks, use teflon sparingly
Old Apr 18, 2013 | 01:03 PM
spate51's Avatar
I will check the sender. I did use the tape. Thanks
Old Apr 20, 2013 | 09:23 AM
woodie582's Avatar
Same issues here, except needle would peg hot..it was the gauge.
Old Apr 20, 2013 | 09:32 AM
You should not need teflon tape as the it's pipe thread and they seal against themselves.
Old Apr 20, 2013 | 02:45 PM
Del70's Avatar
I used the b w d WT 203 on a factory rally pac. No issues. I first started with another brand and it read hot. The car was not running hot. I mapped the temp/resistance on the stove - it was off from the spec Maybe it was a bad unit, not sure or its rang was not compatible. I bought a different brand - the b w d w t 203 and it worked just fine.
54oldz
Jun 20, 2012 07:13 PM
Emreozd
Feb 19, 2012 06:27 AM
ent72olds
Jun 22, 2009 07:57 PM
Sam Barrett
May 26, 2009 11:27 AM
KQQLCAT
Nov 8, 2007 04:48 PM
