Tach adjustment?
There is a hole on the back that has a circle piece of tape over it. If you remove the tape there is a screw in the hole and you can adjust it a little with that screw. Just remember that if you get it adjusted correctly on the low side it don't mean it is correct on the high side.
RAMBOW
May 3rd, 2022 04:25 PM
