Subwoofer location - 68 Convertible
Old Jan 1, 2017 | 07:02 PM
dmberendsen's Avatar
Does anyone know of a decent subwoofer that actually fits under the passenger seat of a 68 cutlass convertible? Thanks.
Old Jan 1, 2017 | 07:15 PM
bccan's Avatar
Just one alternative thought that worked for me. I hung a "Bazooka Tube"(or equivalent, 8" IIRC)from my trunk torsion springs. Works great, excellent bass, stays out of the way. Might need something to limit side sway, either a bumper and/or strap if it is biased to one side. Mine is to the right as I have fairly large Alpine 5 channel amp on left side of floor "kick up." The only time I have heard it swing far enough to thump is doing a quick, dry burnout @ track and that's only once every year or two, doesn't hurt anything. Been in there for over a dozen+ years.
You will be very limited on what will fit under the seat but I remember seeing an ad for such a unit. Another alternative is a sub that sits in your spare tire. You also might be able to conjure up something behind rear seat where the roof pump is. Problem is a decent sub is generally not very compact.
Old Mar 16, 2018 | 08:19 AM
68442Convertible's Avatar
Depends on the seats. On my bucket seats, the space between the steel frame pieces is only 8 3/8". Rockville makes an 8 inch sub (SS8P) that is 8.3 inches wide, so it might fit. But the connectors and controls are on the side (versus the end) so they may not fit. I decided to not try. Everything else I looked at was too wide - and I looked at a lot.
If you have a bench seat, you might be able to get a 10 inch Rockville under it - or maybe even 2 of them.
I wound up putting an 8 inch Bazooka 250W in the trunk on the left side. Just fit.
Old Mar 16, 2018 | 08:34 AM
Pics of the Bazooka going in. Made a mount using a 2x4 bolted to the floor of trunk to raise it up - otherwise it hits the sloped section. Bass bounces off the rear of the trunk and goes forward.
Old Mar 16, 2018 | 08:39 AM
Rockville 8 inch. https://www.rockvilleaudio.com/ss8p/
Old Mar 17, 2018 | 06:16 AM
Are you one of those BOOOM BOOOOM BZZZZZ BZZZZ BZZZZZ guys that has awesome bass, even outside the car, yet your license plate rattles? I've got no problem with epic bass, but when someone is sitting near me with it, and parts of their car are rattling and sounding horrible, it ruins it. People need to listen to their system outside of the car, too, to make sure it doesn't sound stupid.
Old Mar 17, 2018 | 03:18 PM
cdrod's Avatar
Rodney
^^This^^ -I hate it when some gang banger rolls up next to me at a stop light and his whole car is rattling louder than the engine!
Old Mar 24, 2018 | 11:01 PM
cjsdad's Avatar
Keep in mind that it is difficult to get accurate bass response from the trunk of a convertible but it can be done. Most of it will disappear out the rear at highway speeds with the top down though so don't be disappointed. A pair of those Bazooka Tubes, one on each side, mounted facing the rear will be the easiest. Since bass is non-directional, mounting the speakers facing the rear has nothing to do with "bouncing" forward. It has to do with increasing the sound pressure. Think putting your thumb over the end of a water hose. Before permanently mounting the tubes move them forward and back from the rear of the vehicle to find the sweet spot.
Old Mar 24, 2018 | 11:19 PM
cjsdad's Avatar
Gang-Bangin' got nuthin to do with rattling a car. As a 15 year veteran of the '80s and '90s stereo wars I can tell you that rattles come from all walks of life. But yeah, take care of them rattles!
Old Mar 25, 2018 | 08:39 AM
I wanted to show that the 8 inch Bazooka will fit in the space. There is just enough room at the front and rear of the tube to put a small rubber bumper. It doesn't stick out past the lip of the trunk opening, so there is room in the trunk for plenty of luggage. I attached some pics showing the clearance. This is with the tube mounted 3 1/2 inches above the trunk floor on a 2 x 4.
When I inherited my car, it had a power amp and CD changer where the Bazooka is now and a giant subwoofer box that took up half the trunk space. Even worse, I could not really hear it with the top down while driving.
The 8 inch 250W is loud enough to hear with the top down while driving, but not by much. Good enough for me. It does have an amplified output for a second 8 inch that you could mount on the opposite side of the trunk. This is a passive 8 inch that only cost about $100 and will double the bass if find you need that. If you have a powered antenna on the right side it will be in the way.
Old Mar 25, 2018 | 08:44 AM
I should add that the Bazooka website has info on positioning in the trunk, getting better bass, getting the bass from the trunk to the passenger compartment, etc. that is worth reading.
Old Mar 28, 2018 | 09:36 AM
QMaster's Avatar
When I bought my car it had a CD changer, amps, capacitor, lots of plywood, and a giant box with 2 12" subs firing up all in the trunk. In the passenger compartment were 8 speakers. It did not sound good. I ripped it all out (150Lbs), and replaced it with 4 speakers in the passenger compartment, and a small amp with 2 6.5" subs hung between the trunk springs firing forward. It sounds reasonably good. All in it is about 25Lbs of stuff and leaves the trunk useable.
Old Mar 29, 2018 | 05:30 AM
When I redo mine, the only bling I'm going for is stock AMFM 67 radio, with rear speaker, and a 1966 reverberator. I'll get new speakers off turnswitch.com
Old Dec 5, 2018 | 12:48 PM
Rosie39j's Avatar
Mind if I ask where your four interior speakers are? Great looking car...
Old Dec 6, 2018 | 03:43 PM
If you have a convertible, finding space is a tall order. In the rear, the top hydraulic rams take up a good deal of space (and they rotate as they operate). I spent considerable time finding space, finding the appropriate sized decent speakers & fabricating my installation. If you have questions, ask.
Old Dec 6, 2018 | 08:18 PM
gs72's Avatar
72Cutlass S
Old Dec 6, 2018 | 08:58 PM
don71's Avatar
same but different
Originally Posted by gs72
Ha!!! a sub that looks like a NOS bottle. That is killer.
Old Dec 17, 2018 | 09:55 AM
QMaster's Avatar
Like Vintage Chief, mine are in the front kick panels & rear side panels. The previous owner already had them in those locations (and others), so I kept those 4 locations.
Old Dec 17, 2018 | 10:47 AM
boese1978's Avatar
My personal experience says otherwise. I have dual 8's mounted in a box in the trunk. I can drown out any and every road noise etc, even with the top down on the freeway, plenty of "bump"
Old Dec 17, 2018 | 10:58 AM
cdrod's Avatar
Rodney
Another option is to use these under the seats:
Most of the low frequency information from a sub-woofer is felt, not heard. These "bass shakers" will use the floor of the car to transmit the low frequencies so you can feel them. Parts-Express has them on sale right now for $40 ea. They handle 50w each at 4Ω and you can wire them in series-parallel for more power handling; two of them will handle 100w@2Ω or four of them will handle 200w@4Ω. They work best crossed over at 100 Hz or lower.
Rodney
Old Dec 24, 2018 | 07:30 AM
Rosie39j's Avatar
On my 69 convertible with bucket seats I couldn’t fit the Rockville, Pioneer, or custom Auto sounds under the seat (or at least the mock ups I made replicating their measurements, and tested the actual pioneer). Seat bars are too narrowly spaced for it to fit. I went with a box in the trunk, happy with it so far...
Jacoz70442
Jul 8, 2018 11:56 AM
Bowtie-Bri
Feb 17, 2018 06:36 PM
otis12
Feb 20, 2017 07:33 PM
srbz
Apr 10, 2015 06:53 PM
donfitzgerald
Nov 3, 2014 09:07 AM
