Stock electrical connector supplier
I am replacing/upgrading the headlights and found out it requires some disassembly to access the bulbs. I also found out several other things that were just rusted together(trim ring screws) and cobbled together( turn signal wiring) It was faster to just cut and splice the wires rather than disconnect them. The new turn signals that I have seen are offered with a pigtail that would need to be spliced in. What I was wondering, is there a company that offers new versions of the stock plug type connector that I could install on the new lights' pigtail?
turn signal wiring
kept finding more things that needed to be addressed
turn signal wiring
AuVeCo and its resellers. The system you’re looking for is called Packard 56 and you can get all the factory style connectors you’re looking for.
I’d advise you to go a bit bigger wire gauge on the battery to junction block, alternator output and cables to the starter motor. Olds didn’t underbuild, but if you’re in there doing wiring why not update and go a bit bigger? High amperage connections need thick wires.
Cheers
Chris
Cheers
Chris
I also suggest using heat shrink over your crimp connectors. You can get it pretty reasonably from Horrible Freight or even Amazon.
https://www.harborfreight.com/120-pi...set-67530.html
I normally use Del City to purchase Packard 56 connectors, I'm not 100% if they sell the exact headlamp connector, but as Chris said most of the connectors are Packard 56 connectors.
And, like Jesse (Olds64) stated, always use some heat shrink insulation to cover wiring crimps/splices. Besides Harbor Freight, you can purchase heat shrink at most big box stores in your area e.g. Lowe's, Home Depot, Ace, etc. - look in the electrical section.
Depending how many previous owner fixes you’re expecting, consider building a little supply box of various wire-size terminals, both male & female and a collection of plastic shells, both male & female.
I use one of those craft plastic boxes with the dividers to organize parts. Knowing you have the right parts on hand and where they are removes a lot of the friction against getting these kinds of repairs done. It’s also a good way to make factory style connections for stuff you add on like gauges and stereos.
I also keep a separate box of non-GM generic stuff like butt connectors, various sizes of ring connectors for times when they work better than the Packard system.
Cheers
Chris
Cheers
Chris
If you are interested in correcting the wiring defects the right way and eliminating those unslightly crimp splices I attach a page from the Packard Electric Wiring Harness Manual that will greatly assist you. Note: crimping and soldering.
Happy Motoring!
Happy Motoring!
Happy Motoring!
Again, Thank you all for all of the good information!
Happy Motoring!
Packard connectors
I have purchased Packard style connectors housings and terminals from Texas Industrial electric; they have good pricing and small minimum purchase quantities.
https://www.texasindustrialelectric...._terminals.asp
Rodney
Rodney
Rodney
Rodney
September 24th, 2017 12:56 PM
