steering horn
steering horn
hi guys
i'have a problem wiht steering horn '67 Delmont,if I press the two buttons on the steering wheel does not play but if I remove ub steering and hit the cables it works.
I wanted to know if it is to be replaced and if theres a spare or if you have any photos of how it should be mounted, the service manual does not see well makes this part.
thanks
thanks
Check the contact surfaces in the horn "buttons". Sometime a slight bit of corrosion (due to age?) will stop the horn from working. After cleaning, a application of some anti-oxidant will help prevent it from returning.
does not exist an overhaul kit?
thanks
Hey Guys
the price is very very hard
could go for my Olds?
http://www.oldsobsolete.com/products...ct-nos-395741/
