Stealing power.
Old Jun 30, 2017 | 01:25 PM
330jetstar's Avatar
Stealing power.
Where can I say the best place to get power in a 1964 Jetstar. I'm running 4 new gauges under the dash.
Old Jun 30, 2017 | 01:36 PM
What gauges are you adding? Normally mechanical gauges just require a light with the exception of the volt meter. You can tap into the dash lighting and also tap into any 12v keyed power source for the voltmeter in the fuse box.
Old Jun 30, 2017 | 01:39 PM
330jetstar's Avatar
Stealing power.
Old Jun 30, 2017 | 01:49 PM
330jetstar's Avatar
Mechanical oil and temp. Volts and a tack.
Old Jun 30, 2017 | 01:57 PM
Follow the wiring diagram for the tach and use the same 12v source as the volt meter. I tie my grounds to the bottom of the metal dash.
Old Jun 30, 2017 | 02:01 PM
330jetstar's Avatar
Ok I don't have a factory Tach. The manuals I have are for a 1964 starfish not sure if the wiring would be the same I would assume so.
Old Jun 30, 2017 | 02:04 PM
Your adding an aftermarket tach that should have come with a wiring diagram correct?
Old Jun 30, 2017 | 02:06 PM
330jetstar's Avatar
Once I get it I'm sure it will I have the oil gauge thus far. I purchase just one gauge to get sizes. I made a under dash interior colour sheet metal panel.
Old Jun 30, 2017 | 02:16 PM
A lot of us add these items to our cars, pretty simple. They are great for detecting minor issues before they become major.
socalrs
Aug 14, 2012 11:07 AM
squirell
Apr 13, 2011 05:22 PM
Uly49
Oct 20, 2009 07:11 PM
KZ442
Apr 10, 2009 03:16 AM
1FSTLS1
May 30, 2008 07:42 AM
