Starter
There was recently some discussion of this at https://classicoldsmobile.com/forums...t-soak-168757/
caution
A word of caution. Notice the two different style field cases. The one on the left is the early style. It has a shorter narrow section. As Joe noted, high torque and low torque can be determined by the location of where the field strap exits the case. The high torque will be closer to the end of the case like the one on the right. BUT, the case on the right is a later style case with a longer narrow section, and both low and high torque field strap can be located at the same exit point on this style case. When looking at the later style case look for the number of straps that exit the case. 1 being low torque and 2 being high torque.
green1972
May 29, 2022 07:20 AM
