Speedway Motors
Speedway Motors
https://www.speedwaymotors.com/Oldsm...tor,10180.html
This last week I finally go around to working on 1971 Cutlass. The previous owner had upgraded to an HEI distributor but his wiring is a little confusing. I went and got Speedway Distributor, see the link, to replace the one that came in the car. I have been trying to figure out how he had his wiring done. I found this connector with a resistor on it. It looks to have a similar end as the one that plugs into the distributor but I am not sure why it has a resistor on it. Any ideas?
I believe that's the resistor and plug which resides on top of the TVS - Transmission Vacuum Switch located on the passenger side next to the water pump. I'll see if I can find a picture for you. They (PO) probably no longer used the TVS and just let it hanging maybe.
Here is a black & white from the CSM. Also, referred to as the DVCS (Distributor Vacuum Control Switch). The plug inserts into the top of the DVCS and has a resistor on it just like the one you're holding in the 1st image. I'll try to find the image I'm referring to in another post which Eric (the other) and I just resolved for another user when his shorted out.
Here is the link to the thread and a picture (below) of the plug w/ resistor.
https://classicoldsmobile.com/forums...e-blew-136880/
It looks to be the same type plug and resistor although yours appears green.
BTW, if you don't see a DVCS, someone removed it. Also, if the plug isn't hooked up to the DVCS but the DVCS is still installed, chances are someone decided not to use the DVCS - many people bypass the DVCS. The key is to hookup the vacuum hoses correctly if you or someone before you elected not to use the DVCS.
I don't see why you bought a new distributor to fix the wiring, but not a problem. The plug with the resistor is the TCS (transmission controlled spark) solenoid plug that is attached to the top of the DVCS. If the valve has been removed and bypassed, wrap the plug in electrical tape or large heat shrink and wire tie it to the harness. The wires in your hand in picture 2 are the original points distributor resistance power wire and bypass wire from the starter, both used to connect to the coil+ terminal. You can also put heat shrink on them and tie them to the harness. Run a 12ga wire from the fuse box IGN terminal to the BATT terminal on the HEI plug and your done. If you have a tach, it connects to the TACH terminal next to the BATT terminal in the HEI plug.
Like I said above, you just need the one wire from the fuse box IGN terminal to the HEI distributor BATT terminal and the engine will run. Set your timing and carb, then clean up the old wiring.
