spark plugs
Don't go ... japanese... I really think so......
Okay, so AC isn't what it used to be -- their plugs are no longer made right there in the plant in Flint, Michigan...... at least they took their own equipment down to Mexico.... still think it is far better than a Japanese plug that has no business being in a ----- REAL AMERICAN CAR !!!!!!! -----
But that's mine and 200,000 other Americans opinions.............
Call me, I'll let you know what the book says is the correct heat range --
Craig -- 516 - 485 - 1935.... New York.....
There is an Autolite, (Fomoco) plug
that is every bit as good as the R-45S.
I believe it is an Autolite 46? Does that sound right?
It is the Ford equivalent of the A/C R-45S.
I have not run them in a while, but they are excellent,
made in the good old USA. ( I hope.)
NGK, while having U.S.-based operations and manufacturing facilities, is a Japanese-owned company.
Autolite spark plugs are now made by the same company that makes Fram filters and Prestone antifreeze, and the company is New Zealand-based.
NGK's website says this about resistor plugs. They're basically saying you should use nothing but.
http://www.ngksparkplugs.com/techinf...aqresistor.asp
bob p
April 10th, 2015 01:55 PM
