Slight Hesitation in Starter - Follow Up
Thanks to all who responded to my previous post about a slight hesitation in starting. Based on the advice, it seems to me replacing the battery cables and stater (perhaps) is the way to go. My question is this: how difficult is it to replace the starter on a 1972 442 engine? Is this something I could do myself in my garage or does it require a shop setting? Replacement starters are not that expensive, so I am leaning toward replacing the starter and the battery cables all at one shot.
Replacing a starter is SUPER easy. The hardest part will be lying on your back under the car while you support the starter above your head once it is loose. If you have a jack, some safety stands, and a rachet set you can replace it yourself.
Since you are replacing the starter, go with the heavy duty model if you can find one. From what I remember, the HD one will have four field coils, instead of the standard 2 field and 2 shunt.
This is supposed to eliminate any hot-start issues withthe starter.
Also, make sure you have the wide (4") heat shielding side bracket installed. I think the 455's came with them. The 350 usually got the 1" wide bracket. Often the brackets are discarded when cheap shops change starters as they can be difficult to get on.
Clean and Jerk
Same deal trying to install an automatic transmission with your belly.
If you don't have jack stands. find the highest street curb near you house and put the driver side wheels up on the curb and crawl under the car and change the starter. This works best in the rain, as the water can run down your shirt and out the pants leg, helps keep you cool when you get mad taking the starter out and reinstalling. Note: don't forget to disconnect the battery before you start. Changed lots of starters over the years this way. Also works for U-joints
If you have an extra jack stand, place it just under the starter when removing the bolts, it can rest there while you are positioning it to remove the wires befrore ya stretch the bejeezus out of them. Oh, you will pinch your hand there, but hey, just part of the experience. That's how I learned French! You may also just have your exisiting starter rebuilt to heavy duty specs. I did mine that way, works very well.
Since the old one lasted so long, I would have it rebuilt, or at least hang on to it till you are sure the replacement will be satisfactory. The 2 shunt field starter has more power (torque) less speed. Good for big motors.
The belly transmission install is a lot easier when it doesn't have 12 quarts of fluid in it.
Starter removal works a lot better with the battery disconnected especially when laying in multiple quarts of trans fluid.
But seriously, 72442, I agree with you, the cables and the battery and you should be ready to go.
You guys left out the most important part-drive the car about 30 miles immediately prior to removing the starter so that it is hot enough to melt the skin on the palm of your hand as you try to lower it. Same goes for the transmission fluid...
1965cutlassragtop
Jun 21, 2010 09:30 AM
alan69delta88
Aug 17, 2006 02:13 PM
