Resistance coil wire
Old Feb 8, 2013 | 09:16 AM
woodie582's Avatar
Wondering the purpose of the factory wire to coil positive marked as "resistance wire do not cut". I have a Pertronix unit and original installer used factory wire plus a switched wire to coil positive.
Thanks.
Old Feb 8, 2013 | 09:21 AM
TripDeuces's Avatar
The purpose is to reduce the voltage to the points while the car is running so they don't 'burn up'. It reduces the voltage to roughly 8v while running.
Your Pertronix requires 12v to run effectively. You can just remove the resistance wire and replace it with standard wire or use it to switch a relay that supplies 12v
Old Feb 8, 2013 | 04:19 PM
woodie582's Avatar
Key on it gets 12 and change volts.
Old Feb 8, 2013 | 04:21 PM
TripDeuces's Avatar
Did you check it while it was running?
Old Feb 8, 2013 | 04:28 PM
woodie582's Avatar
Nope. Working on wiring now. I thought that might have an impact. I will not use factory wire. Thanks
Old Feb 8, 2013 | 04:31 PM
Funny you should ask...
https://classicoldsmobile.com/forums...tml#post506414
Old Feb 8, 2013 | 06:57 PM
woodie582's Avatar
Good info there Eric. MAD enterprises is also an excellent site to learn wiring and charging info. I am converting the previous owners 1 wimpy wire alternator set up to 3 wire internal regulator. With a lot of reading and asking a few questions I actually feel comfortable with the re-wire.
pbob42
22
May 28, 2013 10:38 AM
RandyS
Sep 12, 2012 02:40 PM
defiant1
May 3, 2011 08:52 PM
jag1886
Jan 12, 2011 07:37 AM
New'n72
Oct 10, 2007 04:42 PM
