Repairing 61 Starfire Turn Signal Switch
Old Feb 21, 2019 | 01:46 PM
Olds Dad's Avatar
Collector of Stray 55's
After a few weeks of chasing out various electrical gremlins associated with a car that's sat most of its life, I discovered that the turn signal switch was bad.
None of my turn signals worked -
Per Service Manual I checked the fuse (good); replaced flasher with a good known one; checked for power at the flasher from the fuse block; checked continuity between the other flasher tab and the orange wire at the switch.
So I called Fusick to get a new switch but they're backordered...
I decided to see if I could fix it - and I did..and saved $65!
HERE"S HOW: -
Step 1 - I Carefully bent back the tabs to separate the plastic housing from the metal mounting bracket. BE CAREFUL - there are 4 ball bearings that will drop out (ask me how I know).
Step 2 - Open and Inspect - my contacts were dirty, grooved, and the grease was essentially solidified.
Step 3 - I used some emery paper to file down the contacts to a level surface - after I was happy with them I cleaned everything with CRC QD Electronic Cleaner
Step 4 - I used dielectric grease on all contacts and moving parts and reassembled - the ball bearings go into little grooves at the base of the interior plastic switch and roll between the switch and the metal bracket - I used a small pair of C-clamps to help hold everything together while I re-bent the tabs into place.
Now it works like new as do my turn signals! This switch is the same for 56-62 (non F-85) so hopefully this will help someone out!
Gordon
Old Dec 19, 2019 | 08:43 AM
KC1962's Avatar
What an awesome post! I'm having issues with my brake lights and turn signals on my '62 working strangely and suspect the turn signal circuit switch as the culprit. I was going to replace it but now thinking I may give your repair method a shot. Thanks for such a detailed post about this!
ankerclanker
Oct 30, 2016 10:17 AM
409/409
Oct 23, 2014 09:08 AM
radioburningchrome
Sep 27, 2009 07:55 AM
66ninetyeightls
Sep 6, 2009 08:34 AM
martine
Jan 22, 2009 01:13 PM
