Relay Question
Relay Question
Does anyone know what the pins on this relay do?
It's an early '70's Olds blower motor relay I believe.
I don't have access to be able to test one. I'd like to know if it is a Normally Open or Normally Closed relay, and which pins are the coil pins.
Thank you!!
Thank you!!
Difficult to know for sure without a part in hand, but this might help.
https://classicoldsmobile.com/forums...tml#post164540
