Relay Question
Old Jan 28, 2011 | 03:49 PM
FastbackJon's Avatar
Relay Question
Does anyone know what the pins on this relay do?
It's an early '70's Olds blower motor relay I believe.
I don't have access to be able to test one. I'd like to know if it is a Normally Open or Normally Closed relay, and which pins are the coil pins.
Thank you!!
Old Jan 28, 2011 | 06:23 PM
BILL DEMMER's Avatar
Just the facts...
it'll be a normally open, with a meter or a test light you can determine the coil pins.
bill
Old Jan 29, 2011 | 06:42 AM
Lady72nRob71's Avatar
I believe the coil pins are the two on the left in the botton picture.
An ohm meter or a low current power supply can let you know for sure.
Old Jan 30, 2011 | 08:37 PM
Thanks, but like I said, I don't have access to one to be able to test it.
Old Jan 31, 2011 | 03:20 AM
Aceshigh's Avatar
If you look at the wiring schematic for it, typically that will tell the tale.
Old Jan 31, 2011 | 05:19 AM
Difficult to know for sure without a part in hand, but this might help.
https://classicoldsmobile.com/forums...tml#post164540
Old Jan 31, 2011 | 04:38 PM
I looked through some of the other posts but don't see any of them that reference this exact relay...
pcard
May 14, 2014 01:21 PM
Houston_t
Oct 25, 2012 07:10 PM
JBrooks
Tech Editor's Desk
Sep 9, 2012 03:25 PM
mmurphy77
Mar 5, 2011 03:49 PM
96 aurora
Aurora
Sep 6, 2006 03:49 AM
