Rear Defogger Wiring Help Needed
Old Nov 5, 2014 | 08:22 PM
Boilerz25's Avatar
I am starting to put my car back together and I am wiring the dash up and I am having trouble figuring out the wiring for the stock rear defogger. I purchased all new harnesses from American Autowire and just want to know how to run the wires from the dash switch to the defogger in the rear. The car is a 69 442 Holiday Coupe.
I looked at the wiring diagram but can't find anything.
Sean
Old Nov 5, 2014 | 08:39 PM
oldspackrat's Avatar
They run through the plastic sheath under the drivers seat to the trunk area. Then there are a couple? clips that secure it to the rear of the back seat back, if that makes sense.
Old Nov 6, 2014 | 03:34 AM
Yellowstatue's Avatar
At some point, the defog harness has two wires. One is for high speed and the other is resistance wire for low speed.
Old Nov 6, 2014 | 07:16 AM
I've removed a handful of these options from cars & have always found the resistor wire right beside the main wire in the plastic sheath.
Old Nov 7, 2014 | 06:57 AM
Boilerz25's Avatar
Thanks guys. My main issue is the switch has a three wire harness coming off the back. I do not know how I tie this into a powered circuit. I have the wiring that runs to the back of the car and that is not the issue. I was really hoping if someone had a diagram for the entire circuit.
Thanks again
Sean
djd71355
Alero
Mar 11, 2014 11:09 AM
caddy
Apr 2, 2011 05:54 AM
My442
May 23, 2010 02:45 PM
Flye
Jul 7, 2009 07:59 AM
vette442
Jun 8, 2009 11:14 AM
