rally pack fuel gage
Old May 1, 2015 | 03:32 PM
1of32442w30s's Avatar
While checking lights in cluster (gage removed) my mistake put 12v on the fuel indicator gage! Then gage showed full, so guess I shorted resistor. How do I replace the resistor and what type resistor do I need. Jim
Old May 1, 2015 | 06:20 PM
jensenracing77's Avatar
Have you installed it back in the car. It could still be ok.
Old May 1, 2015 | 07:06 PM
oldspackrat's Avatar
I don't know if it is the same or not but when I restore regular fuel gauges, I put 12v. to one side of the gauge & ground the other side to see if it moves, then reverse the leads to check for movement the other way. I'm not sure if you damaged the gauge but maybe try reversing the leads but only touch them for a quick second to see if it moves the other way?
Old May 2, 2015 | 05:08 AM
Without a signal from the sender it will read past full, doubt you hurt it.
Old May 3, 2015 | 04:47 AM
yes and shows over full
Old May 3, 2015 | 04:48 AM
Will remove gage and try reversing 12V, thanks all for the feedback. Jim
costpenn
Dec 28, 2013 08:39 AM
StickW31
Jan 8, 2013 08:08 AM
StickW31
Jan 7, 2013 08:30 AM
louie
Apr 11, 2011 06:07 AM
junior4053
Nov 21, 2010 10:06 PM
