Radio replacement suggestions.
Old Dec 28, 2021 | 01:02 PM
Cutlass Fan's Avatar
Not sure if this is the right place to ask this, please move if not. I want to replace the original radio in my 65 Cutlass (which doesn’t work) without cutting the dash. Will a din1 fit in the stock opening? Unfortunately I can’t afford one of the modern retro radios. At present there is a cheap older cassette radio on the glove box. I’m open to any suggestions.
Old Dec 28, 2021 | 02:06 PM
Yellowstatue's Avatar
You can have your original radio retro-fitted with AM/FM and other fancy stuff such as blue fang.
Old Dec 28, 2021 | 02:47 PM
No, a modern single din will not fit your dash without cutting. There are many inexpensive single din stereos that will fit in the glove box while your stock radio is just left installed for display only.
Old Dec 28, 2021 | 03:36 PM
The retro fitting is a little pricey. Guess I’ll end up with it back in the glove which is a pita.
Old Dec 28, 2021 | 06:09 PM
I discovered there are 3.5" round radios for boat applications that would be a good fit into an empty clock or gauge pod. Amazingly full featured for the size.
broman
Jun 6, 2020 08:21 AM
ART T
Oct 22, 2018 04:09 PM
71cutlassdroptop
May 18, 2014 07:39 PM
SevenNoOni
Nov 1, 2013 10:30 PM
defiant1
Mar 14, 2010 11:11 PM
