Radio replacement suggestions.
Not sure if this is the right place to ask this, please move if not. I want to replace the original radio in my 65 Cutlass (which doesn’t work) without cutting the dash. Will a din1 fit in the stock opening? Unfortunately I can’t afford one of the modern retro radios. At present there is a cheap older cassette radio on the glove box. I’m open to any suggestions.
No, a modern single din will not fit your dash without cutting. There are many inexpensive single din stereos that will fit in the glove box while your stock radio is just left installed for display only.
