question about map light draining battery. please help!!
Old Jul 20, 2007 | 09:42 PM
branemi's Avatar
I just bought a 95 olds cultas cierra about a month ago. My battery went totally dead, so I replaced it. I then noticed that one of the map lights stays on all the time, so it it what is draining my battery. If I take out the lightbulb, will the light still run power off of my battery? I'm also having problems getting to the bulb. Should I unscrew the lightbulb or cut the wires in order to save the battery?
Thanks so much fo your help!
Old Jul 20, 2007 | 09:46 PM
Omicron's Avatar
Site Admin & Motorhead
Taking out the bulb will most likely fix the problem. Without the bulb the circuit is not complete and no current flows. Give it a try and see what happens, it's definitely the cheapest and simplest potential fix!
Vistabrat72
Nov 9, 2022 04:37 PM
66BOAT
Nov 6, 2013 12:53 PM
Joffroi
Dec 16, 2012 08:45 AM
projectheaven
Jan 27, 2008 06:13 PM
pinky
Nov 5, 2007 01:59 PM
