Pulsating Headlights
Old Jan 1, 2009 | 10:08 PM
mark8918's Avatar
Talking Pulsating Headlights
Needing help with pulsating lights. First off I have a 1970 oldsmobile cutlass
that I purchased 7 months ago, I have done a lot of work to it and now ran into a problem that I can not fix. My headlights seem to pulsate or dim and
brighten when the engine is on, I have changed the alternaor and still the
lights seem to pulsate. When you give it gas it seems to stop but only for 2-3 seconds and then continues to surge or pulsate. Thanks in advance for any help you can provide. Oh by the way does anyone have a wiring diagram they
can scan and shot my way, would surly appreciate it, thank markm.
Old Jan 2, 2009 | 12:44 AM
EKi's Avatar
EKi
Try checking and cleaning all connections in the headlight circuit, they could be corroded causing unnecessary resistance. Also you could consider adding relays to make the circuit shorter thus having less connections and less resistance. Here's some info http://www.madelectrical.com/electri...adlights.shtml
Old Jan 2, 2009 | 03:37 AM
rocketraider's Avatar
Oldsdruid
Check and clean all ground connections including the voltage regulator mounting screws, and the engine-to-chassis ground straps.
Sometimes a weak headlight switch will cause this. The switch has a circuit breaker inside it.
Bite the bullet and buy yourself an original 1970 factory Chassis Service Manual. It will have clear color wiring diagrams that generally lose a lot in a scan, in addition to other invaluable service information.
Old Jan 3, 2009 | 07:32 AM
zed's Avatar
zed
Just to echo what these guys said, that was happening with my old Dodge pick up. I found that the hot wire going to the amp meter in the dash was very corroded. Cleaned it and put a new end on it and no more problem. (other than it still being a Dodge)
Old Jan 3, 2009 | 09:01 AM
ozoneblue's Avatar
pulsating lights
Are you sure your belts are good & tight ? Does the alt run off the crank or water pump if its the pump the Ps belt is slipping
Old Jan 3, 2009 | 06:26 PM
mark8918's Avatar
Hey guy thanks a bunch your quick answers help alot, all I did was check all my ground and found the horn relay was not grounded good enough. With a little bit of cleaning fixed the problem, no money required.. I will be posting a pic. of my project car make sure to check it out..
Thanks Mark.....
scooter123
Sep 28, 2013 07:32 PM
DuezPaid
Nov 3, 2007 01:21 AM
gregghunter
Aurora
Jul 21, 2007 02:13 PM
ventport
Alero
Nov 5, 2006 04:17 PM
Jaked
Sep 3, 2004 04:45 AM
