power windows
Old Mar 1, 2012 | 07:22 AM
donald8619's Avatar
power windows
Have 71 W-30 conv.Having problem with main swicth for windows.Changed the relay windows on both sides operate individually(passenger frt & back & driver back)but none from drivers main switch.All switches are new.Thanks Don in sunny NC
Old Mar 1, 2012 | 09:41 AM
Highwayman's Avatar
The wiring harness at the door jam gets flexed every time the door is opened. You could try checking for continuity. It wouldn't be the first time a wire was broken.
Old Mar 1, 2012 | 09:51 AM
Rickman48's Avatar
Yes, check there first - usually pretty obvious!
Old Mar 1, 2012 | 10:16 AM
frankr442's Avatar
What was it doing before you replaced all the switches? Can't really tell from your post exactly when the problem started.
Old Mar 1, 2012 | 04:57 PM
donald8619's Avatar
Replace the contact block for driver swicth work fine. window was not closing to my liking so took it apart again,that's when the problem started.will check for broken wire inside door. Thanks Don
socalrs
Aug 14, 2012 11:07 AM
squirell
Apr 13, 2011 05:22 PM
rustycarr
Mar 7, 2007 06:24 AM
jrbarrie83
Jul 4, 2006 09:16 AM
Geoffrey Hacker
Aug 1, 2004 01:05 PM
