Power Window Crossover Location
For a 1970 A body convertible, does anybody know the correct routing in the dash for the crosover harness that runs from D side to P side for the power windows? My car came disassembled so no help there. There is a pretty vague reference in a drawing in the Fisher Body manual but it doesn't really show the actual path. I can find no clips or screw tabs that would provide clues. Does it just run across the inside top (if that makes any sense) of the metal structure or...?
The harness under the dash feeds the passenger door. The rear left and right windows feed back from the driver side and the right rear feeds along the lip behind the back seat and drops to the floor as in the pics provided above.
Rodney,
Thanks!! The pictures were perfect. My car also has power locks so this shows exactly where everything goes. Now I need to find some wire clips that will work. No one seems to be reproducing them.
jaunty75
May 31st, 2011 05:39 PM
