Power top switch...
Old Jun 1, 2025 | 06:12 AM
Tancuda's Avatar
Power top switch...
Hi all,
want to install a universal power top switch on a 71 cutlass, what should be the minimum amps rating for that switch ?
I saw on internet that I could use an isolation relay (that will take the heat) and use a lower amps switch (more model available).
Any tips or idea.?
Old Jun 1, 2025 | 06:28 AM
Funkwagon455's Avatar
Correct replacements are available.
https://www.hydroe.com/top-switch-1970-1972-cutlass/
Old Jun 1, 2025 | 07:04 AM
Tancuda's Avatar
Thanks for the reply,
I know I could use the replacement, but I would also need the harness for it,
and the cost with shipping here in canada would be pretty high. So my client decide to
go with a universal one and the only one I found is this one....NEW 1971-1975 Oldsmobile Delta 88 Convertible Universal Top Switch | eBay
I believe that I can't go lower than 50 amps right ?
Old Jun 1, 2025 | 02:32 PM
cfair's Avatar
As I recall the circuit breakers for that switch pop at >40 amps. That implies the switch needs something just below 40 amps.
From what I’ve seen Olds used fuses up to 30 amps and above that they used circuit breakers.
Either way, wire it through a safety device.
Chris
Old Jun 1, 2025 | 05:37 PM
cdrod's Avatar
Rodney
My convertible pump motor is protected by a 30A circuit breaker that has never tripped. In full disclosure, I have all new bushings in the top mechanism, and new pump and ram cylinders; an older set-up may draw more current.
Old Jun 1, 2025 | 05:50 PM
Tancuda's Avatar
Thanks everybody, I opted for the 50 amps switch instead of the 30 and will use the same wire.
Tancuda
Nov 2, 2024 03:20 PM
PaulWinn
Dec 29, 2022 02:41 AM
matt69olds
Jul 11, 2022 04:16 AM
425HP409
Feb 19, 2021 05:13 PM
JOHNNYOLDS442
Jun 11, 2020 07:59 AM
