Power seat problems...
Old Apr 19, 2016 | 12:22 PM
holidaysedan's Avatar
'79 Olds 98 sedan. Motor whirrs when the button is pushed but no movement in any direction. Seat also has Power Recliner option (separate button on seat bottom, not on the armrest) which DOES work. Thoughts?
Old Apr 19, 2016 | 12:47 PM
Professur's Avatar
The seat rails are rusted solid.
Old Apr 19, 2016 | 12:53 PM
If the motor runs but there's no movement, usually the clutch or clutch solenoid are bad, or wiring thereto.
Old Apr 20, 2016 | 06:02 AM
Thanks fellows... I lean towards the latter possibility as there is no trace of rust in the under-seat structure, or anywhere else for that matter on this never winter-driven car, and the back-rest recliner works just fine, I assume that is a separate circuit and mechanism. Need to get a Fisher body FSM, don't believe it's covered in the chassis manual.
chasman414
Jun 25, 2020 07:05 AM
69442murph
Jul 9, 2014 04:55 AM
Ddbord
Jun 19, 2012 02:08 PM
White Spyder
May 27, 2012 10:38 AM
KZ442
Apr 10, 2009 03:16 AM
