Please en-lighten me...
Old May 14, 2025 | 03:58 PM
Biggreek65's Avatar
I feel kind of dumb, however I have a 1972 cutlass supreme convertible. When I hit the brakes, the front parking lights turn on also. Any thoughts are appreciated.
Old May 14, 2025 | 04:53 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Grounds.
Chase down the light harness grounds.
The other grounds will need attention too. Its a 54 year old car. All other grounds need the same attention.
Old May 16, 2025 | 06:37 PM
Check for ground problems at the TAILLIGHT sockets. There is no electrical connection from the brake light circuit to the FRONT light sockets under normal conditions. If the rear tail light sockets have bad grounds, the brake light circuit will ground through the park light circuit, which DOES have a connection to the front sockets. That is the only way for the brake circuit to apply current to the front park lamps.
Old May 17, 2025 | 09:31 AM
Dynoking's Avatar
Is it possible that single contact bulbs have been installed in the stop lamp sockets?
Old May 17, 2025 | 05:19 PM
cjsdad's Avatar
Ding Ding Ding! If a single element (1156) light bulb is installed in the brake light socket instead of a dual element (1157), the brakes and turn signals will feed power into the parking light circuit.
Old May 17, 2025 | 05:42 PM
Someone brings this up every time. I have to say that in over 50 years of working on these cars, I've never seen this done. One has to be pretty clueless to force an 1156 into an 1157 socket. The bayonet pins are not in the same locations and you really have to jam it into place. Can it be done? Yeah, but if one is that clueless and unable to sense the fact that the bulb is being forced into the socket incorrectly, I shudder to think what else is screwed up on that car. Far more likely is a bad ground at the tail light sockets, which will cause the same effect. Also, if the contacts inside the socket are damaged or spring out of position, this can also cause cross-shorting between the two circuits.
Old May 17, 2025 | 06:55 PM
cjsdad's Avatar
Yo Joe! I love saying that. Reminds me of Saturday morning cartoons. Yes I know the bulbs should not be able to cross polinate, but I had many, many customers come back to the stereo shop claiming "it didn't do this before!" They would spend a little cash on a new stereo for their new-used vehicle, change a few bulbs to make all the lights work and somehow manage to crank 1156 bulbs into the brake light sockets. Some of them would still argue the point even after I showed them the difference. It happens way more than you I would imagine.
Old May 18, 2025 | 08:24 AM
Dynoking's Avatar
In my forty seven years I've seen it more than once. For an inexperienced DYI apparently it's not as difficult to do as you think. The first time I saw it was when a "experienced" mackanic literally had the entire dash wire harness and steering column pulled apart on a mid seventies Econoline Van. The shop owners cousin (not a mechanic) looks at the mess, asks why the vehicle is disassembled and states oh I had the same problem on my ______ and it was the wrong bulbs in the taillights. After three days of hair pulling the problem was solved in thirty seconds. I'm not saying this has to be it but it is worth mentioning. Never say never.
Old May 18, 2025 | 09:39 AM
OLDSter Ralph's Avatar
Joe P. You may find it hard to believe that there are clueless people. But "THEY DO WALK AMONG US".
Old May 18, 2025 | 12:08 PM
cjsdad's Avatar
And they reproduce...
I know I have done my share of stoopud things.
Old May 18, 2025 | 01:10 PM
Rallye469's Avatar
I DO NOT think Joe has a hard time believing the clueless hold a strong majority in our society.
Old May 18, 2025 | 02:14 PM
It's not as hard as you think with some of these offbrand bulbs.
ANDY B07
Aug 27, 2022 06:16 PM
pettrix
Sep 22, 2020 02:59 PM
Gixxerg
May 5, 2019 05:44 PM
deadeyejedi
Mar 4, 2013 04:21 PM
Pete77
Jun 14, 2006 07:07 PM
