parking lamps/head lights
Are the parking lamps, the amber lights int he front bumper supposed to be off when the head lights are on? when i pull the the headlight switch out to the first position they are on, then when i pull the switch all the way out to turn on the head lights they turn off. is that correct?
If you want your park lights on with the head lights, then remove the park light wire from the switch and move it to the right rear corner of the switch where the unused terminal is.
