parking lamps/head lights
Old Apr 16, 2014 | 01:46 PM
88jetstar's Avatar
Are the parking lamps, the amber lights int he front bumper supposed to be off when the head lights are on? when i pull the the headlight switch out to the first position they are on, then when i pull the switch all the way out to turn on the head lights they turn off. is that correct?
Old Apr 16, 2014 | 02:57 PM
mrolds69's Avatar
It's absolutely correct, 1st detent is the parking lights, second is the headlights w/o the parking lights. That's how the older cars were.
Old Apr 16, 2014 | 04:08 PM
+1. Newer models, starting, I think, in 1968, had them all come on at the same time, and had one fewer terminal on the headlight switch.
Old Apr 17, 2014 | 03:35 AM
Yellowstatue's Avatar
If you want your park lights on with the head lights, then remove the park light wire from the switch and move it to the right rear corner of the switch where the unused terminal is.
Old Apr 17, 2014 | 01:36 PM
88jetstar's Avatar
Thanks for the replies guys
rjohnson442
Jan 21, 2014 01:15 PM
lshlsh2
Apr 12, 2012 04:47 PM
TripDeuces
Aug 3, 2010 07:20 AM
1966_F85
May 14, 2010 03:03 AM
Jura
Oct 31, 2009 02:50 PM
