original 442 alternator date coded ?
Old Aug 26, 2016 | 09:16 AM
Bitburger's Avatar
Are alternators date coded ? I have what I believe is an original Delco Remy 69 442 alternator.
It has the following numbers on it:
1100691 42A
5L1 - 12 v neg
I'm guessing 42 amp and twelve volt negative ground but what about the other numbers ?
Old Aug 26, 2016 | 09:25 AM
jensenracing77's Avatar
The 69 442 had an open face alternator and the fins on the back. I don't know off the top of my head what the numbers are but the back of that one for sure is not original to the 442. Is the front an open face?
Old Aug 26, 2016 | 09:44 AM
70-442-W30's Avatar
344879M363895
According to this site, it is to a 66 Buick A-body w/V-8
http://www.v8buick.com/archive/index.php/t-74774.html
Old Aug 26, 2016 | 09:48 AM
70-442-W30's Avatar
344879M363895
Forgot the build date...it would be November 1st 1965
Old Aug 26, 2016 | 10:46 AM
steverw's Avatar
Looks like an internal regulator alternator to me, at least the back half does. I dont think they were available in 65.
Old Aug 26, 2016 | 11:05 AM
70-442-W30's Avatar
344879M363895
The back half doesn't match the active or closed listings on eBay for the ones they have on there for 1100691. So something's up.
Old Aug 26, 2016 | 12:34 PM
Bitburger's Avatar
Two pics added. does the last one show the fins you mentioned ?
Old Aug 26, 2016 | 12:36 PM
Bitburger's Avatar
So then the date code is the 5L1. How does that decode, what means what ?
Old Aug 26, 2016 | 12:59 PM
70-442-W30's Avatar
344879M363895
First digit is the year = 5 for 196(5)
Second is a letter for the month - A-Jan B-Feb C-Mar etc. "I" is skipped. L=November
Third is the day = 1
Old Aug 26, 2016 | 02:32 PM
Bitburger's Avatar
Ok, and does this hold true for date coding on Oldsmobile / A body / GM in general for other parts as well ?
Old Aug 26, 2016 | 04:02 PM
70-442-W30's Avatar
344879M363895
I'm just going by what I was told to decode my own alternator date. I don't have any solid knowledge for you on parts other than this. They all seem to have their own little secret decoder needed.
Old Aug 27, 2016 | 06:12 AM
Bitburger's Avatar
Ok thanks
Old Sep 16, 2016 | 09:39 PM
stevengerard's Avatar
For many parts yes it does, others like seat belts are 21 E 69 which is 21st day of May 1969. Carbs have the day and the year so a 70 W30 carb would be 7040258 (part number) Date code 3329 would be 332nd day of 1969
Old Sep 17, 2016 | 04:48 AM
70-442-W30's Avatar
344879M363895
Bitburger, if you take a look at my auction listing, it should give you a good idea of how the dates were determined for each major component. I just didn't have the individual info for each one handy when I first replied to your inquiry before. It took me going back through all of my posts. Should have written each one down as I went.
Old Sep 17, 2016 | 05:16 AM
70-442-W30's Avatar
344879M363895
I'm glad you posted this because I found an error in my listing. For the carb date I put the 25th week of 1969. OOPS! Went by memory on that one...guess I shouldn't have.
Old Sep 17, 2016 | 08:09 AM
Bitburger's Avatar
Ok great, thanks for the info
Brad
jim larson
Apr 1, 2016 02:13 PM
#171Cutlassman
Oct 25, 2010 08:06 PM
monzaz
Drivetrain/Differentials
Jan 28, 2010 12:13 PM
1BAD68"S"
Feb 15, 2007 07:38 PM
