original 442 alternator date coded ?
Are alternators date coded ? I have what I believe is an original Delco Remy 69 442 alternator.
It has the following numbers on it:
1100691 42A
5L1 - 12 v neg
I'm guessing 42 amp and twelve volt negative ground but what about the other numbers ?
1100691 42A
5L1 - 12 v neg
The 69 442 had an open face alternator and the fins on the back. I don't know off the top of my head what the numbers are but the back of that one for sure is not original to the 442. Is the front an open face?
According to this site, it is to a 66 Buick A-body w/V-8
http://www.v8buick.com/archive/index.php/t-74774.html
Two pics added. does the last one show the fins you mentioned ?
For many parts yes it does, others like seat belts are 21 E 69 which is 21st day of May 1969. Carbs have the day and the year so a 70 W30 carb would be 7040258 (part number) Date code 3329 would be 332nd day of 1969
Bitburger, if you take a look at my auction listing, it should give you a good idea of how the dates were determined for each major component. I just didn't have the individual info for each one handy when I first replied to your inquiry before. It took me going back through all of my posts. Should have written each one down as I went.
Aug 8, 2017 10:44 AM
jim larson
Apr 1, 2016 02:13 PM
